No of visitors who read this post: 167
Category: PCs
Type: Question
No votes yet
I am having some trouble with the deleting process. Each time I try to send something to the recycle bin it just shows permanently delete message. I do not know to undo these settings and need some assistance for this. Should someone know the method for this please kindly reply.
Christian Briggs
Error:
Delete File
Are you sure you want to permanently delete this file?
New Microsoft Office Excel Worksheet.xlsx
Type:Microsoft Office Excel Worksheet
Date modified: 3/9/2012 1:40 PM
Comment viewing options
Hey Christian!
Whenever we delete any file by pressing right click on the file and select delete, these files straightly move to Recycle Bin.
These files are not actually deleted but these files stays in Recycle Bin for you. If you found any file useful in Recycle Bin that you deleted earlier, you can restore that file by pressing right click on the file and selecting Restore file.
When you right click on Recycle Bin and select Empty Recycle Bin, Your computer says that are you sure you want to delete files permanently?
If you select yes, you cannot undo it. Once file deleted, you cannot get it back. Somehow there are some software in the market that can be use to restore the deleted files.
you can search for them on internet.
Here is the link for one:
http://www.recovermyfiles.com/
Thanks
