Today my E: is showing me that I only have one file on it. That was my official documents drive. When I checked E drive properties from my computer its show 20.9 GB used and 30 GB free. I active show hidden and system files from tools menu but it doesn’t work.
How can I fix this problem ?
Something corrupted that drive and you are unable to see your files. If you want to recover them you can find a huge number of tools. I will recommend a few which are mostly used in such situations.
I hope your drive is a hard drive.
