Fedora 17 Installation failed at the end
I have a Fedora 17 installation pack. When I tries to install, it failed at the end when it try to write grub2 configuration to the disk. There was no further messages or nothing, it just failed! Can someone tell me a solution for this? I very anxious about this.
Answered By 0 points N/A #135231
Hello isabellartd,
Welcome techyv.com. Try to burn the ISO file to the disk again in a slow mod not x4 the slowest the burn speed the better. Or re download the disk image again but do not use any illegal downloader. Have you also checked your bios sometimes bios has a default operating system to be set either vista or XP if you see that there is just change it into an other operating system.
And do please post also the your computer specs because sometimes hardware that's not supporting Linux is a problem also and also try to use the entire disk when installing the Linux base operating system you can change that after the installation by using applications like Gnome Parted or the Hard disk Manager itself of Fedora.
