FaceBook Comment Box Personalization Help
Hey Friends,
I am working on Facebook integration on my website. The font of the comment box however looks terrible. Is there any way I could personalize the font of the comment box. I prefer "Verdana"
Do help me if you have encountered the same problem in the past and have found a remedy to it.
Thanks
Answered By 0 points N/A #98408
Hi Kim Fonseca,
Seeing comments in Facebook with terrible font sometimes irritates eyes and make you not to press the like button. It is easy to hit the Red X mark at the right hand corner if the page and it’s features does not appeal to your likeness.
Below are the instructions to customized FacebookFont;
  • Log-in to Facebook.
  • Go to “Applications” Scroll down and Browse More Applications.
  • Type font in the “Search Apps”.
  • Select the list of Font in the menu. Select Verdana if it’s on the list.
  • Click on Font Application Icon. Then press the blue “Go to Application”.
  • Click “Allow” then this will should change the Font you’ve selected in your comment space.
 This should make you customize the looks and how should display in your comment text. Hope this increase your follow and numbers of Likes in your page.
Good Luck!
