Explain Detail About Delete The Outlook Data File From Outlook 2010?
I am using outlook 2010 installed in Windows 7. It has two accounts. One of which I no longer use and I want to get rid of it. Is there any way by which I can remove it from the list or delete the outlook data files and account from navigation pane?
Answered By 0 points N/A #108373
To remove the Outlook data file or Personal Storage File(PST) it is possible through Control Panel.
Step 1: Open Control Panel and Select Mail
Step 2: Select the mail which you want to set as default which will not be deleted until the mail window is open.
Step 3: Highlight the PST files that you want to remove and click remove.
Step 4: Now go to outlook.
And Right Click and select “Close outlook data file” So the file will be removed from the list.  
