Exchange Error ID 80090308 on Viewing Public Folders
Hello Guys I am trying to view public folders using Exchange System Manager and I get this error.
I know we have a Fully Qualified Domain Name of our server on SSL How can I solve this issue?
Please help.
The token supplied to the function is invalid
ID no: 80090308
OK
Answered By 0 points N/A #118912
Hi there, so you are having a trouble with your Exchange System Manager .
                Base on the research I did was to simply remove SSL from the Exadmin virtual root In IIS. In the properties of the virtual root exadmin in IIS, try to do this following procedure click “Directory Security” tab  and then you will see “Secure Communication “ section select “Edit”. Make sure to deselect “Require secure channel (SSL)” and “Require 128-bit encryption.” If the “Require 128-bit encryption.” Is selected and grayed out. Make sure to select “Require secure channel (SSL)” and deselect “Require 128-bit encryption.” then deselect “Require secure channel (SSL)” again
Hope this will help you.
Matt tiger.
