No of visitors who read this post: 629
Category: Exchange Server
Type: Question
Author: Arturo owen
No votes yet
I get this error on Exchange 2010 Setup Error in an inconsistent state. This usually happens when an idea is reinstalled or the substitution host has been uninstalled.
Error:
Some controls are not valid
I need help to resolve this error.
Comment viewing options
Dear Arturo owen
According to the error you received, this issue may occur if the previously Exchange installation or removal failed to finish. This situation leaves the Exchange server object in Active Directory and prevents a new Exchange from installation. A resolution of this problem is simply to remove the Exchange server object in Active Directory.
In order to do this please follow the procedure explained in this webpage which is submitted by Microsoft Exchange server technet: http://technet.microsoft.com/en-us/library/cc411332.aspx . You should use an account delegated a membership in the local administrators group to perform this procedure. And the ADSI (Active Directory Service Interfaces) can be run from a client or server computer.
Hope this may help you.
Best of luck
