The exception unknown software exception 0xe0434352 occurred
Even if my PC and my drivers are updated I still have some error cause by the programs. This is one of them, it is caused by Kaspersy application and I don’t know anything about. Does anyone have a solution for this ? What is causing this ?
Thanks !
Avpui.exe – Application Error
The exception unknown software exception (0xe0434352) occurred in the application at location 0x74c82eec.
OK
Answered By 590495 points N/A #171940
If you have Kaspersky Internet Security 2014 and it shows an error every time you open it, this is maybe because it lacks a component or a required software that maybe you forgot to install. There is really no problem installing Kaspersky Internet Security 2014 on Windows 8 because it is fully supported.
Kaspersky Internet Security 2014 supports Windows XP [Home or Professional] Service Pack 3 x86 only, Windows XP Professional Service Pack 2 x64 only, Windows Vista [Home Basic, Home Premium, Business, Enterprise, or Ultimate] Service Pack 1 or higher, Windows 7 [Starter, Home Basic, Home Premium, Professional, or Ultimate] Service Pack 1, and Windows 8 [Professional or Enterprise] both x86 and x64.
Kaspersky Internet Security 2014 requires the following components that you need to install: Microsoft .NET Framework 4, and Microsoft Windows Installer 3.0. Since you are using Windows 8, you can ignore installing Microsoft Windows Installer because I think the operating system has a much higher version. If you don’t have .NET Framework, download it from Microsoft .NET Framework 4.0.
