Ethernet Options in using Music Production
Asked By 210 points N/A Posted on -
I have a MAC computer and I need to know the Ethernet options available in my computer. What are the advantages of this option and its purpose? Also, what is Music Production in MAC and its usage? How effective it is to use the Ethernet options in using music production?
Answered By 75 points N/A #125631
Hallo Koby,
Music Production in MAC is a utility that allows you to record music and videos like you were in some kind of studio. It allows you to edit the music. The music production utility has the following features:
·         The music production has Audio and MIDI interfaces, and also it has External MIDI sound generators, such as samplers and synthesizers which enable to edit the music and make its quality better.
·         There are also External audio devices, which include mixers, audio converters, pre-amplifiers, channel strips, effects units which also enable editing the music.
·         Another notable feature is the Amplification and speakers for stereo or multi-channel surround mixes, helping you configure the music in terms of the sound dissemination.
Hope this helps.
__
Regards
Lee Hung
