I’m stuck with the following error message when I try installing virtualbox for Windows 7. As far as I can guess, the cause is a faulty windows 7 image file. So I re-copied and validated the md5. Then the error disappeared.
Error:
Windows cannot install required files.The file may be corrupt or missing.Make sure all files required for installation are available and restart the installation.Error code:0x80070570
The error is explaining every thing. That you have missed out something in the installation package or that you have access problems or that the Operating System has some files that are not compatible to the software or that the O S files have been corrupt or out of date. This is the main reason for the error. To resolve all the difficulties, you must update the O S and then repair it. The second is that you obtain a valid copy from the premium user. Then you need to reinstall all the packages and the O S. This will take time.
