I am having a serious problem while trying to install Adobe AIR on my Mac, I’m running OS X 10.5 leopard, A while after launching the Adobe AIR installation a window appears citing this error:
I’ve checked over and over that the account I’m using has administrator privileges but the problem is far from being solved I hope I would find an answer her and thanks
Error:
An error occurred while installing Adobe AIR. Installation may not be
allowed by your administrator. Please contact your administrator.
Cher1
It seems as if you have an older version of Adobe Air already installed on your machine. Before attempting any installation of adobe Air, please check your system to ensure one was not installed before. If so, you need to uninstall that version and install the current version. In addition, you must have administrator’s privilege for installation of Adobe Air to be a success. To uninstall previous version of Adobe Air using your Mac machine, go to:
If you are still having trouble uninstalling it, use this command sudo "./Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer" -uninstall.
When you have uninstalled Adobe Air, please proceed to installing the newest version. You can also visit http://www.adobe.com/support/documentation/en/air/2/releasenotes_users.html for more info.
