I am trying to install Windows XP on an Intel Mac using an ISO turn mortal repeat of the Windows installer is more than twice as fixed as using the installer CD. However, I ran into a thin problem after completing the Windows installment. I utilized a slipstream Windows XP Plate installer with Writer Take 2 to pose Windows in VMware Merger.
After Windows booted up, I encountered a failure when I proved to activate the Windows Firewall from Test Committee: System error 1075 has occurred. Any help will greatly be appreciated.
Hallo Elias,
To resolve the issue that you are getting, install the Client for Microsoft Networks network component using the following steps:
Carl
