No of visitors who read this post: 175
Category: Misc Software
Type: Question
Author: David Mills
No votes yet
Hi. I’m a new user of Cisco unity. When I try to install the program, I get the following error message.
"Setup
The following problem was found while verifying that system meets the installation requirements:
Unable to open a SQL connection to the Master database
Call Technical Support"
Please help me. Thank you.
Comment viewing options
 Actually, the information in this document is based on Cisco Unity 4.x. Here in this document explicate the recommended work “Unable to open a SQL connection. Call Technical Support” error message that appears in the installation of Cisco Unity. It is recommends that you have knowledge of Cisco Unity.
The information here, in this document was generate from the devices in a specific lab environment. All devices used in this document ongoing with a default configuration.
Just complete these steps: At first, you have to ensure that SQL installed in the Cisco server. Then ensure that the MSSQLSERVER runs on the server. If it does not work then you have to restart the MSSQLSERVER first and then install Cisco Unity.
To more learn please visit : Cisco Unity
