habert
Posted on - 06/19/2012
Hello Experts,
I’m using Windows Vista, and my Desktop Manager is 6.0. I’m now running with a problem with synching with my Outlook Calendar 2007.
Every time I try to set it up, it asks me which way I would like to sync (two ways, from BB to outlook, from out look to BB).
But whenever I click next, an error message appears. After that the program just crashes, and I get back to the DM 6.0 software.
I also uninstall and reinstall DM 6.0 but the same thing happens.
The operation terminated unexpectedly
Any suggestion is appreciated.
Thanks a lot.
Error Synching With My Outlook Calendar 2007
The caused of the error to occur is the entries of Intellisync configuration folder has been damaged and it is mandatory  to be erased.
I will provide you the solution which has been successfully performed by others .Please perform the following simple steps to complete the synchronization process properly.
1. Go to C:Documents and then navigate to this folder Settings[user_name]Application DataResearch In MotionBlackberry.
2. Next step, please right-click on the Intellisync folder and select Delete.
3. Afterwards, open Blackberry Desktop Manager .
4. Finally, double-click on Synchronize and then select Synchronize now in order to complete the process.
I hope this will assist you in solving the issue.Â
