Error: “SDC00400”, someone knows this?
I was just about to a download software, but it was unsuccessful with error: "SDC00400". What is this? If you initiate a download finished ELMS and get a fault codification of SDC00400 (No Link), this could connect anything from the computer state fancy at the point or the Internet memory was temporarily straying. It may also be akin to individualized firewall software on my computer. Specifically, this fault encipher is presented for.
Any suggestion? Thanks.
Answered By 0 points N/A #144637
This error often happens when you change the destination folder for your downloaded files.
The defaults folder is c:Temp.
We can change the location so that the file downloads directly into a folder we want it saved in but there are some files that will not allow you to download directly into a different folder and it’s these files that give us the error.
The only thing we can do at this point is to make sure that the destination folder for the downloaded files, software etc is c:Temp.
You can just copy and paste the files on the folder you want to save it to.
Hope this helps
