Error in running Management Reporter Migration Wizard
With Dynamics, we have received an error message from running the Management Reporter Migration Wizard. The error says “The version of the database is incorrect. Install the correct version of the database.” Does anyone have an idea on the causes and fix of this error?
Answered By 0 points N/A #101800
The problem you are facing is that your DB has encountered a problem and the solution is inside the error as it says install the correct DB exactly you are facing this problem. So recover this problem and you will get running your software you are installing the incorrect version of the DB which is not compatible with the software so use the DB which is correct and match the software you are using.
Hope this solution is fine for you and you will get rid of the problem using this solution. This is the solution which has also given to you by the error message.
