selina965
Posted on - 06/18/2012
Has anyone tried running doujin Visual novel True Remembrance?
I managed to install it, but when I open the launcher (true.exe) the game crashes and a blank error window appears.
I can’t seem to find out what the problem was since it was blank, and I was hoping someone knows how to fix this.
I managed to get a screen shot of the blank error window, here:
TRUE REMEMBRANCE
Help Me
Thanks
Error Running Doujin Visual Novel True Remembrance
If you are running Windows Vista on your computer, I don’t see any problem running this game on your machine. But if you are using Windows 7, and I think you are, then this is really a problem since it will not work on this kind of platform. Shiba Satomi’s True Remembrance works only with Windows 2000, Windows XP, and Windows Vista. If you want to play this one, you might consider installing and running it on a virtual machine that runs with either of the three [3] operating systems mentioned above.
If I’m wrong about the version of your operating system then might as well try reinstalling the whole game. Uninstall Shiba Satomi’s True Remembrance and then check your computer for any possible errors. Use a disk utility application to check the system. Install the game back after this and then see if this fixes the problem.
If you want more information about this visual novel game, you may visit True Remembrance — Shiba Satomi’s True Remembrance.
I think I’ve already answered your question regarding this problem with this visual novel game Shiba Satomi’s True Remembrance. It seems that the game you are trying to play is completely not compatible with your computer’s operating system. Shiba Satomi’s True Remembrance works only with Windows 2000, Windows XP, and Windows Vista. If you really want to play this visual novel game, you might consider running it on a virtual machine that runs with either of the three [3] operating systems mentioned above.
If I’m wrong about your operating system then might as well try reinstalling the game. Uninstall Shiba Satomi’s True Remembrance and then check your computer for any possible errors. Use a disk utility application to check the system. Install the game again after this and then see if this fixes the problem.
For more information about this visual novel game, you may visit True Remembrance — Shiba Satomi’s True Remembrance.
