Error is registering assemblies. This is an administrative task, permission denied
I am having a problem concerning a “.dll” installation to the GAC.
The error message tells me that I do not have administrative access or administrative credentials for the task.In other words it tells me that I am not the administrator.
Any ideas why this is happening?
Thank you in advance.
Error
This is an administrative task, permission denied.
System.ApplicationException: Unable to install assembly in the GAC. This usually indicates either an invalid assembly path or you are not admin. At EasyHook.NativeAPI.GacInstallAssembly(IntptrInContext, String InAssembly, string InDescription, String InUniqueID)
EasyHook.Config.Register(String InDescription, String[] InUserAssemblies)
At scanner.Form1.g()
C:program filesRVG SoftwareHoldem managerHEMGUI.dll
C:program filesRVG SoftwareHoldem managerHSFtp.dll
Answered By 15 points N/A #181579
Hi Jamal,
The error is because the current user does not have the correct permissions for the registry key.
To resolve this error follow the below steps:
1) Log on to the system as Administrator
2) Click 'Start', Click 'Run', Type 'regedt32'
 Open-Registry-Editor-through-Run-Window
3) Click on the subkey  'HKEY_CLASSES_ROOTComponent Categories{62C8FE65-4EBB-45e7-B440-6E392CDBF29}'
4) Click 'Permissions' on the Security menu
5) Click 'Advanced'
6) Click and select 'Inherit Permission from Parent Object' check box, Click 'Apply'
7) Close 'Registry Editor'
8) Restart the system
