Error in Perfect Job software
I have been facing an error in using perfect job software which I recently downloaded. Actually I downloaded a trial version and whenever I try to start it, it shows the message saying "905 Fatal Error: The message itself says: "5074 The Index 'Unique_Username' is dependent on column 'Username'. ALTER TABLE COLIMN Username failed because one or more objects access this column. Dommand: /****** Version: 1.0.1.13 ******/ ALTER TABLE [dbo].[User} ALTER COLUMN Username vachar (255) nul;” Splash screen says Version 1.0.4.96…Updating Database Schema…" Please help me out in resolving this issue. Thanks.
Answered By 10 points N/A #120710
You have said that the perfect job software is a trial version, and therefore it could be way past its period that is needed to be used, and thus I will suggest the following workaround for you:
  • Download the application from a different site because the one you downloaded may be corrupt.
  • Download the software again from its official website and not from other sites. You can download it from PerfectJob™ – Better Jobs. Faster.
Before you download the application check the system specifications of the computer and be sure that you are downloading the right version. You can also try reinstalling the application in case the installation process had some flaws.
Thompson Locker
