An error occurred while initializing LevisCheck
I was installing LevisCheck on my computer and the installation went well. But suddenly an error occurred when I was opening my browser which is Internet explorer. Other browsers such as chrome can open but IE cannot. Was this problem caused by the new installation?
An error occurred initializing Lexis Check.
Answered By 0 points N/A #181503
Hello
You did not mention the version of IE. I believe it could be because you are using an older version of IE. Try install the newer version and also update Active X Controls. Follow; Internet Options->Security->Custom button->Enable .Net Framework-Related Components->  Enable ActiveX controls and plug-ins.
Also, in Scripting-> Enable Active Scripting->Allow paste operations via script->Scripting of Java applets and click ok. It should work.
Thank you. TechyV.
