shekh321
Posted on - 09/16/2011
I'm facing the following problem. I want to Reinstall Nokia Ovi suite on my PC for mobile connection but I get this error message."Something’s gone wrong There was a problem. Please restart Nokia Ovi suite and try again. If the problem persists, uninstall Nokia Ovi suite and download the latest version of the application from: http://www.nokia.com/global/support/nokia-suite/
Does anybody know the solution to this problem. Please help me. Thank you
Error :
Reinstall device software
Something's gone software
There was a problem .please restart Nokia Ovi Suite
and try again . If the problem persists ,uninstall Nokia
Ovi Suite and download the latest version of the
Error code : 12017
jakia01
A error in Nokia Ovi suite reinstaller
Hey Shekh,
Try this:
1. Uninstall the program.
2. Also uninstall the browser you are using – Mozilla Firefox, as this is the browser attached to the Ovi account.
3. Setup using the upgrade version which is now available. But keep the existence in registered. Don't install the free low version. It will not give as much speed as you need.
4. Ensure enough disk space on your PC for these apps. Connection line fees and service provider fees must be cleared before starting.
5. Windows network availability is required.
Thanks…..
Hello Shekh,
Thanks that you have shared your problem with us.
Dear this is not a very big problem.
You have a need to update your software. The Software you are trying to install may be expired version or corrupted.
Uninstall this completely.
Restart your computer.
Download the latest version of the Nokia Ovi Suite and install it on your machine.
Your problem will be resolved very easily.
Try this one
https://nokia-ovi-suite.en.softonic.com/
I hope it will help you a lot.
Thanks
