Error in newdev.dll: Missing entry: ClientSideInstall
I am trying to install Epson Stylus C84 InkJet Printer, when I plugged in the USB cord for the printer, I received a newdev.dll error.
I downloaded newdev.dll and copy it in system32 folder but the error remains.
How can I fix this error?
RUNDLL Error in newdev.dll Missing entry:ClientSideInstall
RUNDLL
Error in newdev.dll
Best Answer by Zorian Crust
Answered By 80 points N/A #161207
Put the XP CD into the CD drive and then try the following:
Start > Run – then type in "expand X:i386newdev.dl C:WindowsSystem32newdev.dll" – without the quotes
[Where X=your CD Rom]
And the same is applicable for hotplug.dl, just put hotplug.dl instead of newdev.dl
Or update the latest service pack in this link:
Zorian
Answered By 0 points N/A #161208
Put the Windows Xp (your OS) CD/DVD into the drive and try the this:
"expand X:i386newdev.dl C:windowssystem32newdev.dll"
Ignoring the quotes NOTE [ X = your DVD Rom drive lable]
You may try a system restore to check if the issue is solved.
This should probably solve your issue. If not contact tech support for more information.
