Error message “URL ends with an invalid top..”
Hi guys, During I tried to get access on these site- https://accounts.google.com/ServiceLogin?passive=1209600&osid=1&continue=https://get.google.com/albumarchive?source%3Dpwa&followup=https://get.google.com/albumarchive?source%3Dpwakchristian219 or https://accounts.google.com/ServiceLogin?passive=1209600&osid=1&continue=https://get.google.com/albumarchive?source%3Dpwa&followup=https://get.google.com/albumarchive?source%3Dpwa into GA URL – frequently I get an error message which informed me that: URL ends with an invalid top-level domain name – Please give me a solution. Thanks a lot
Best Answer by Carl Jack
Answered By 0 points N/A #95163
The error you received means you are entering a website with incorrect URL address.
You may have included something in your address that is supposed to be not included.
Why not try to remove the username on your first URL, instead of typing
https://www.google.com/photos/about/
Just type https://accounts.google.com/ServiceLogin?passive=1209600&osid=1&continue=https://get.google.com/albumarchive?source%3Dpwa&followup=https://get.google.com/albumarchive?source%3Dpwa. Or you may also need to check if the address has been changed already. Or simply try removing the http:// on the address. Instead, just type picasa.google.com.
It should work now.
Answered By 10 points N/A #95164
Hello Silva,
You will need to check if you might be associated with the following: http://www.posteravatar.com/.  If you are, then you might be violating the double-serving policy – that is if you are trying to bid on the same keywords.  But in the event that you are not associated with that site, then it is most probable that you are violating a trademark.
Google can sometimes take a hard as well as a confusing line when it comes to not giving you information that could be construed for instance giving out information about your competitors. So you will need to check such issues.
Carl
