Error Message After Installing Nokia PC Suite
I received an error message when installing Nokia PC Suite, It says the Installation Operation Failed.
I can't continue with the installation.
How to resolve this?
I have done the uninstalling and reinstalling process.
Answered By 1065 points N/A #120527
Many users have been receiving series of errors during or after the installation of Nokia PC Suite.
First thing to check is, if there is another program that is also using the Windows Installer Files while you are trying to install the PC Suite.
Try clicking on Start and then Run. Type MSCONFIG and then click OK.
The Startup Selection window will appear. Click on the Diagnostic Mode and then hit Apply.
Restart your computer and then try installing the Nokia PC Suite again.
After the successful installation, revert your PC to Normal Startup.
There are also third-party registry scan application that can fix this problem.
Try to download one and then run it on your computer.
After that, run the PC Suite installation again.
It should work now.
