Error : Internet Connection Problem
Hello experts
I feel may be I have changed a little in regedit so that I can set up Diablo 3 (worked).
However now I get the following problem:
Not Connected You are currently not connected to any networks.
Also,internet is running very well and also all the games as well as general tooting running well but I get lag spikes also Vista Anti-Lag is not running.
I need to fix this, but i don’t know the solution of this. I need your help.
So, please give me a solution.
Thanks in advance.
Best Answer by Fosso pradha
Answered By 0 points N/A #156141
Dear User,
Try these simple steps for solving the current issue you are having,
1.Try re installing your adapter driver from the manufacturer website. If the problem is still there, temporary disable your network adapter and re enable it.
2.Go to run and type ‘services.msc’ in the run box and press enter
3.Click continue if it asks to verify the administrator permission
4.Go to properties of Network Location Awareness by Right Clicking and selecting properties from the drop down menu
5.On general tab please click start and choose automatic for the startup type, then click ok
Restart the computer. Try safe mode to test if possible.
Thank you
Answered By 5 points N/A #156142
Do you use the type of network,GSM, CDMA or Broadband. First  you need to install the LAN Card. Then Open Network and Sharing center>>Set up a new connection or network>>Connect to the Internet>>Select your type of network>? Finally you need User name and Password.
Mohsinaece
