Error during Installation of Corel Photo Paint
I am using Corel Photo Paint. But it is some time annoying.
It gives this error sometimes which feel me stupid, "Product Installation Unsuccessful Please Reinstall Error 24".
I want to get rid of this error permanently.
Is anybody here to help me?
Best Answer by amber stone
Answered By 0 points N/A #119999
Yeah. I understand your problem. I think you are using a pirated version of Corel and that is why you are facing this kind of problem. Try uninstalling the program and then try reinstalling again. This must mostly help because it happens for every pirated software users. You could do that for your every issue to clean up.
Otherwise, you can consider doing this too. Set back your clock to 2-3 months. This will definitely help if not the first one. This will make corel think that your time is not yet expired and you can continue using corel for that specified time. Again the same problem, then do the same thing.
Cheers.
Answered By 0 points N/A #119997
This error mostly occurred when you have installed a counterfeit copy of Corel, or the generated  serial number of your Corel is not legitimate. It is best to uninstall your current version, and replaced it with genuine copy.
But you can also try this so called RunAsdate, it is for free. This “RunsAsDate” lets you use a software or an application below any time and date you prefer, without replacing the actual or current date of your system. Take note that it will run only with the versions of Windows that has 32 bit. You can download it in this website: http://www.nirsoft.net/utils/run_as_date.html
