Error downloading mobile video player for Pocket PC
I tried to install a mobile video player on my Pocket PC but I was unable to so. I encountered an error message saying, “This is not a valid Pocket PC application”.
I am using Windows Mobile 5 and I am pretty sure that what I was trying to download is a program that should run in my Pocket PC. Why did I receive such error?
What I have right now just plays MPEG videos and I want to be able to watch other forms of videos using my Pocket PC. Please help me!
Answered By 0 points N/A #122275
Maybe the application is not compatible to your system because the message pops up to your PC from the application is not valid in your PC just simply check on that and then try to download the Mobile Converter V1.1 free for your windows Mobile just simply install that to your windows mobile 5 and then after you install the mobile converter in your PC and then you just simply try to convert the application from the mobile converter and then try this just simply download other video player that can be suitable to your windows mobile 5 then check the version if it’s compatible from the pocket PC just try that one if it’s working at all.
