The error that the .dll file could not be located.
Hello Team,
I want to discuss on the basic error which I get while using the GIMP software on my computer. It asked to install a plug in and I did as it said. But still I am facing the error that the .dll file could not be located.
Someone please fix this issue and help me out.
Answered By 5 points N/A #143513
When you are facing an error such as these, it means that you're lacking a requirements to launch the software. I suggest you look for the system requirements that this software requires.
DLL issues concerns Microsoft's DirectX component. Its the graphics, media and audio elements which GIMP access.
Try updating your DirectX version. Go to this link.
Then install GIMP software after updating DirectX.
Hope these helps.
