No of visitors who read this post: 207
Type: Question
Author: PaulaDZigler
No votes yet
Can someone help me fix my CCleaner? When I run a scan using my CCleaner, I get a blue screen and an error report that says “SYSTEM_SERVICE_EXCEPTION”. Does anyone have a solution for this? Any help would be much appreciated!
Comment viewing options
Good Day PaulaDZigler,
There are so many things to consider why the blue screen is showing when you  use CCleaner ( or other system utilities). Maybe you have installed new applications/programs that has not passed into the system requirements of your Computer, you have updated your programs, deleted important files located in your registry and it may also caused by virus penetration to your hard drive.
To solve that error, you can run the system restore, (system restore is a default program in your computer and save your recent settings that has no errors.) Using System restore, you can roll back your system settings from the day you install your Operating system, applications and etc. But you must back up your files.
I hope this information helps,
Mark Amna
