My problem is with my OBIEE 10.1.3.4.1. During the time of running of the drill down report an error aroused showing Error Codes EHWH2A7E. I have cleared the caches and the application was restarted. But the problem still persists. Now I am looking for some help from you.
Please take me out of this problem.
An error aroused showing Error Codes EHWH2A7E
James,
The error aroused showing the code EHWH2A7Esince
One: the pivot table that was beforehand referenced no longer encloses the metric range that formerly was selected.
Second: When the pivot table view is used as the added outlook have default indication that attach effectively when parsed.
The Solution would be quite simple.
1st Click the Criteria tab into the Answers Window.
2nd Then click the outlook drop-down and select the pivot table view in query. You should edit the Pivot Table.
3rd As soon as the pivot table edit page turns up you’ll see the Measures box in the pivoting criteria window is blank.
4th Lastly, shift a metric starting the ‘Excluded’ criteria box toward the ‘Measures’ box.
This would help you.
