Error occurred during directory enumeration
Hi..
Please help in this topic.
An error occurred during directory enumeration. I will be very thankful if you solve my problem.
Thanks
Hi..
Thanks
In the Windows Recovery console when doing the dir command you may get the "An error occurred during directory enumeration" error. This error indicates that the computer is unable to read from the hard disk drive and could be an indication of a serious hard drive corruption or failure.
Try correcting this issue by running the below chkdsk command to find and repair any errors.
chkdsk /r
If this is able to complete and you're in the recovery console because Windows is not working properly, remove the disk from the computer and try booting the computer normally. If Windows boots we highly recommend backing up your data and run scan disk on the drive.
If after running this command you're getting the volume appears to contain one or more unrecoverable problems error run through the troubleshooting steps for this error.
When an error occurred during directory enumeration “chkdsk / r” can be used to find the error and repair it.
If there is serious hard drive corruption or failure you even need to boot your computer.
Follow these steps to recovery console from windows XP:
Step 1: Insert your bootable CD-ROM into drive. (Windows XP).
Step 2: Restart your computer and set your BIOS to boot in CD.
Step 3: “Press any key to boot from cd”.
Step 4: Press R to start recovery console when you see welcome to set up screen.
Step 5: Choose windows installation you wish to load.
Step 6: Type administrator password and press enter.
Step 7: When c:windows prompt is seen type chkdsk / r and let it run till completed.
Step 8: Once chkdsk program is complete type exit to reboot windows.
