Error -2147220480 occurred at nisyscfg.lvlib:Export.vi
I have been making vain attempts in importing the configuration of my Measurement & Automation Explorer (MAX) to a disk. I have been trying to achieve this via NI System Configuration API. The software version is 1.1.2
I have been unable to proceed as I am stuck with the below mentioned error
Possible reason(s):
NI System Configuration: (Hex 0x80040400) Error opening a file
Complete Call Chain:
 Export MAX Configuration.vi
Hope you'll can help me with this.
Best Answer by Blando Baly
Answered By 0 points N/A #147726
Hello Dibri,
Have you checked the NIC configuration on your computer? For it seems they haven't been configured correctly and as a result causing the issue. You will need to go to the device manager and confirm that. If the Network Interface Card is faulty you might want to replace it.
Nicke
Answered By 0 points N/A #147727
Good Day Dibri,
The error you encountered is caused when you tried writing to a part of your disk which does not have the appropriate permissions or approved permissions. Try first changing the desired destination folder to the Desktop or My Documents folder and try running the application. If this still does not work, try following the instructions on the following link:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PA7DSAW
Answered By 60 points N/A #147728
Thanks guys for your valuable information. Blando Baly, your solution is nice. After reading your solution, I have realized why this problem is occurring and I have figured out how I will fix this problem. Following your instructions, I was able to fix my problem and I am not experiencing any problems anymore. The link that you provided is very useful. And I think, even in the future, this link will still be helpful for me. Thanks, friend, and thanks to techyv.com, too.
