Error 1460 – Error Code 0x5b4 on Dual boot Operating System
I am running two operating systems in my computer. I made a huge conflict on drive C.
So that my computer becomes very slow.
This creates an error which I cannot remove properly.
I cannot identify this error so please clear this error for me and suggest me to do something to remove this error cause I have some important files on this drive.
Need to save them
The error is:
Error 1460 – error code 0x5b4
Thank you.
Answered By 5 points N/A #99754
Hi there Kelly,
Please see the Description and the Solutions below for Error 1460.
Please note that permanent damage may occur to your PC if Error 1460 – Error Code 0x5B4 is left alone and not repaired immediately.
Microsoft Windows Error Code 1460:
‘ERROR_TIMEOUT’
Error Description
This operation returned because the timeout period expired.
Solution 1:
To repair this error, download and install each of the software tools listed below. These have been specifically designed to help repair this error;
Download Windows Software Update – updates the drivers that control your computer.
Download Error 1460 Error Code 0x5B4 Fix – helps fix Error 1460 – Error Code 0x5B4 on your system.
Sometimes Error 1460 – Error Code 0x5B4 can be caused by spyware or virus infection, so it’s wise to run a virus/Malware removal program to remove any spyware infections. It’s also vital for each and every virus/Malware removal software to be updated on a regular basis to ensure that your protection is also up-to-date.
To begin the installation, once you’ve clicked on the a link above, a new window should appear with several options on it. Click Open or Run this program from its current location. Or to save the download to your computer for installation at a later time, click Save or Save this program to disk.
Once installed, run each program by pressing its scan/update button. Once the checks are done, you can let the tools fix the problem.
Solution 2:
You can also try to reformat your computer as long as you’ve already backed up your important files. In your case, I would suggest that you perform a “clean installation” to rid the nasty remnants of the error that occurred on your computer. If you are not familiar with the secure back-up methods or if you need some help on the reformatting of your PC.
Please don’t hesitate to ping me on this message and I’ll promptly answer your questions.
