Entry point not found error
Hello everyone,
I’ve recently started operating on Windows XP on my laptop and had no problems until now. But after the last time I’ve updated windows I got this error message when I turn the computer on:
A`NSISu_exe – Entry Point Not Found
“The procedure entry point CM_Get_Devise_IDA could not be located in the dynamic link library SETUPAPI.dll.”
If you have any ideas what could be the problem post here. Thank you in advance.
Answered By 0 points N/A #110249
You need to install an anti virus software on your computer and then perform a whole system scan to look for viruses. The might be moved or deleted by a virus.
You can either update your operating system or repair the operating system if viruses are found and deleted. This is to restore you XP to its former self.
Format the system if the virus cannot be deleted anymore. Be sure to backup all of your files that is important.
You can actually download the file but it will just be a waste of time if your computer is jump packed of viruses inside.
