Hi Experts,
I added a task to the Task Scheduler the other day for it to be started yesterday. However, I received this error message when I tried starting it (please see below). I checked the scheduler and it was running. I tried rebooting the PC Server and tried doing the tasks again but I still got the same error.
I am now calling for experts in this forum who can help solve the problem. Please help. I am new to this job.
Task Scheduler
General page initialization failed.
The specific error is:
0x80041315: The Task Scheduler Service is not running.
An error has occurred attempting to retrieve task account information. You may continue editing the task object, but will be unable to change task account information.
The problem is not with the task that you had allocated to the task scheduler to execute but it is with the task scheduler itself. It has failed to initialize and therefore cannot execute the application. Some the reasons as to why it is behaving like that will be because:
To fix the problem, you will need to close down the task scheduler application completely from the task manager, and restart the server to refresh the settings in case it had gone in the idle mode.
Regards
Thompson Locker
Gc777
This error is due to the authentication parameters set on the user / system accounts.
Basically, when you run the task service, there is always a security parameters called the logon information, similarly like windows logon, which tells the task manager when and what to run / perform.
When your computer starts this logon information also starts on the task manager. But in your case the user you are log in does not have specific authority to run this specific task.
What you can do is, change the user log on information on the task manager to the local system account, and to do this perform the following steps:
· On the My computer icon, right click and then click on manage
· Click on services and applications- services
· Locate task scheduler, and double click and click on log on
· Click on the Local System Account and Allow Service to Interact with Desktop- Apply
· Click on general tab, and click on START
Your issue will be resolved
PT
