No of visitors who read this post: 780
Type: Question
No votes yet
Hello experts,
Just I have installed E3D on my PC with AE6. Then I installed the Pro Shaders with Motion Design pack. After that, the effect looks to run very well and also the license key worked in first time but the media is missing. All of the browser windows are missing Materials, Models, Environments or Bevels. Then I have attempted re-installing the fixed but no change. Now what should I do? Do I require registering the position of the media files? Where am I able to get them on the hard disc? Maybe it is not connected but I saw that the installer (zipped) is below 80Meg.
Unexpected Error
An error occurred while installing Element.
Please contact support.
OK
Please give some suggestions.
Thanks in advance.
Comment viewing options
# (Solution Accepted)
Dear User,
I recommend you to download a newer setup file. Not an online installer. But an offline installer. Where you can download all the files in to your hard disk drive and proceed with the installation.
This way you are able to have everything in your hard disk and begin the installation with it. So that you can make sure all the files are available for the installation.
Thank you
Goody Day, upon reviewing your Question and based on the error you got, the reason why you are having that kind of problem is having a corrupted installer or some of its components is missing. I suggest you should download again or you should get a new fresh installer. The reason why I am suggesting to you to get a new installer Is because I have the same file to and its nearly 200 mb in size.
Heres the proof I provide for you:
