Education version of Autodesk during the project
Autodesk gives me for a while some errors and this is one of them. I didn’t find a solution for this and I can assure you that the reinstall of the Autodesk suite is not helping at all. Can anyone help me please to fix this error ?
Thank you !
Educational Version – Plot Stamp Detected
This drawing will display the message, “PRODUCED BY AN AUTODESK EDUCATIONAL PRODUCT.” Do you want to continue?
If you continue, the message will mark this drawing and nay drawings that reference it.
Continue the current operation
The printed output will display the following banner: “PRODUCED BY AN AUTODESK EDUCATIONAL PRODUCT.”
Cancel the current operation
Answered By points N/A #180059
Such watermark indicates that the drawing was, somehow, in its lifecycle, has been edited or modified with an “Education/Student” licensed product. Those products injects the line in purpose to discourage others from using the file for commercial, for-profit or professional purpose.
There’s no way that you can remove the stamp. However, if you update to AutoCAD 2015, such operation will be supported. If you edit the document with AutoCAD 2015 and save it, the mark will disappear and won’t appear until the drawing is again used with any education licensed purpose.
Get AutoCAD 2015.
