Eco Manager bug Windows 7
I have experienced a number of Eco Manager bug Windows 7 environment. One of them is the maximum number of users. Another one is when comparing two revisions of a design, after clicking "Validate" nothing seems to happen. What I do is restart the application and it works fine. But everytime I encounter this problem I have to restart Eco Manager.
Best Answer by Nicke Baker
Answered By 0 points N/A #192775
Hello Jhon,
That is an error that occurs in the old versions of Eco Manager, and therefore to resolve the bug you will need to run the Eco Manager update to install the latest patches and remove the old ones, or you can go ahead and uninstall it and then find the download the latest version and install.
Nicke
Answered By 0 points N/A #192776
Hi Jhon,
If you are having problems with your current software of Eco Manager, install the latest version of Eco Manager from the Internet. You may like to download the software from here.
Another solution would be re-installing the software.
But before that, be sure to backup all your files.
Regards
