EagleSvr exe Unable To Locate Component
I installed an Anti-porn in my PC. The question is, when I restart the PC the anti-porn program does not work and shows me this error. When I re-install the program still gives me this error.
Please help me. Thanks.
This application has failed to start because eagler.dll was not found. Re-installing the application may fix this problem.
EagleSvr.exe – Unable To Locate Component
OK
Answered By 0 points N/A #173948
EagleSvr errors usually have the following reasons:
  • wmvbrcpl.dll file has been deleted (by accident)
  • an error has damaged the wmvbrcpl.dll file and made it inaccessible
  • wmvbrcpl.dll related registry files are corrupt
  • The program related to wmvbrcpl.dll was not properly installed
  • wmvbrcpl.dll was overwritten by a corrupt version
  • Spyware/malware is presenting itself as wmvbrcpl.dll, and the original file was deleted by it
To automatically fix this:
1. Download the repair tool from http://www.fixpcdll.com/AF_ErrorsRepair_Setup.exe and install it.
2. Click Start Scan Now to start the scan.
3. Click Fix All. Everything should work now.
