Ea origin game language selection installation problem.
Hello experts,
Ea origin game language selection installation problem. In the middle of the installation I was asked to select on the language I want to use when accessing the game. But the dropdown button didn’t appear on my computer screen and it says not responding. I already restarted but still the same problem occurred. Please do help me.
Answered By 0 points N/A #184895
You already restarted your system but still the same problem occurred. Now check your Hard Disk Drive storage, maybe its full of program software that cause your system work slowly. Remove some program software that you are not using anymore, decrease your files by deleting some files that are not important and most of all make sure that only the installation is running in your system to avoid the performance sharing in your system.
Best regards,
Heather marie
