Dynamsoft SourceAnywhere Hosted Binary files differ.
Hello people! I have a tool for comparing text or binary files.
But sometimes when I compare two text files this message appears. What does it mean?
Some other files that I compare is ok and do not display this one.
I need info about this.
Best Answer by Harpe byers
Answered By 0 points N/A #116899
  The problem you are facing is due to the following reason:
-> The encoding of the files you are comparing is different, both the files must be of the same encoding.
   Hope this will help
Answered By 10 points N/A #116901
Dear Jackie,
The problem of “binary files differ” occurs because both the files are binary that you are trying to compare.Either of the file shall be non-binary to compare with the other binary file.
Follow these steps to make either of the file from binary to non-binary:
1. Right click on the file you want to convert non-binary,
2. Go to properties,
3. Select General option and
4. Change the file format to non-binary.
I hope the problem shall not appear then.
The other option is to use a “-a”. “-a” considers all files as simple text files.
