Hello experts
Without hitch, I have been running DVD43 for more than a year.
However just I changed my Hard Disc and I am re-installing every program such as, the new version of DVD43 but now I get the following error message:
"The driver is inactive or not installed properly. Please re-install DVD43 to enable the driver."
I find a small gray DVD43 sign on the bottom right of my display and it means the driver is not installed or DVD reader is not found.
Then I am Un-installing and re-installing it but same things. I need your suggestion. Please help.
Hello Anna,
Try the following workarounds and see if they will help you solve the problem:
Carl
Hey Annarforster,
Here are your problem solution just follow the suggestion and i think you will get fixed you problem, Let's have a closer look at the disk being read - As read by your DVD Drive:
1. Close 1 Click.
2. Place the Original Disk in question in the Drive that you were trying to read the Disk with.
3. Open the VSO Inspector to Show how your Drive reads the Disk: http://www.vso-software.fr/products/.../inspector.php
4. Select the Drive containing the original Disk.
5. Media Tab.
Please Post the 'Save Report' VSO Inspector from the Media tab Click the 'Save Report' icon in the VSOInspector tool-bar Save to Desktop
