DreamWeaver template_text.htm, a JavaScript error occurred
Today I install dream weaver in my system now I am trying to open this program but I receive JavaScript error in template_text.htm file.
Please any one tell me how can I remove this error. Due to this error I can’t start dream weaver.
While executing inspectSelection in template_text.htm, a JavaScript error occurred.
        OK
Best Answer by amannan
Answered By 0 points N/A #124788
Hay Loveemma
You would not show which version you used in your PC. Well i have show you some of solutions.
1. The error in Adobe CS2 Dreamweaver means that there is a problem with the graphic card. You need to replace it and reinstall the software for this newly installed graphic card.
2. Adobe CS3 is the best for all PC you just install properly which apps you need and not just disclose from install.
Keep existence install in your PC then you may get the solution that's it.
thanks
Answered By 5 points N/A #124789
Hello emma,
The solution of your problem is simple, to avoid this error you must remove the current configuration file plus the configuration folders. Remove all of them so your Dreamweaver can generate new configuration files for you. How will you do that, follow the simple steps:
1- Go to -> C:Documents and SettingsYour UsernameApplication DataAdobeDreamweaverCS4en_US
2- Here rename your configuration folder to any name, say configuration_old.
3- Run your Dreamweaver again.
It will generate the fresh copy of the configuration file and will work fine now.
Thanks
