Download drivers sd card lenovo ?
Hi Experts,
I want to download drivers SD card Lenovo. Can you tell me a good web site for downloading laptop drivers? I did research on the internet but could not get the compatible driver SD card for Lenovo. Give me the link. Thanks.
Jaylonomarion
Best Answer by Del Cacho
Answered By 15 points N/A #156208
I hear your concern regarding this issue. I would like you to try this website
http://www.driverscape.com/manufacturers/lenovo/cardreader
The website contains some possible downloads of your driver SD card for Lenovo. And for compatibility reasons you have to be more particular with your operating system. Make sure that the SD card that you are going to download is compatible with your current operating system to avoid conflicts and errors.
I hope this suggestion will help you a lot.
Answered By 0 points N/A #156209
Hi Jaylonomarion,
First of all go through your Laptop configuration and Operating system, and note down your laptop model no. Then search in
https://support.lenovo.com/us/en
I have suggest you visit the Lenovo Official website for SD card Lenovo drivers. I have provide the link and you can search
 with model no. and series of laptop.
https://support.lenovo.com/us/endetail.page?LegacyDocID=migr-67470
I hope it will help you.
Thanks!
Answered By 10 points N/A #156210
Hello Jay,
The best place to download drivers on the internet is from the manufacturer’s website, but there are other sites as well that offer genuine drivers.
You will need to do the following:
First of all check your system specifications. Things like what kind of operating system you are using, what model your computer is, and whether your operating system is a 32 bit or 64 bit.
After that go to the manufacturer’s website and use those specs to look for the right drivers.
If you choose to use other sites like Majorgeeks.com, SoftPedia and CNET Downloads to get the drivers then you will need to make sure that you use the specifications to search for them.
Carl
