Download Android 2.3.3 (Latest version)
Hi there everybody!
I have been using Nexus S for all this time and now I want to shift to the latest version of Android, that is Android 2.3.3 but I do not know anything about the download source; how to download; and how to install.
Can anyone help me with this matter and solve this issue as soon as possible?
Thanks in advance.
Best Answer by Franks good
Answered By 0 points N/A #158954
Hello. I have a very simple answer or solution to your problem.
Just visit the site and follow the steps and in just short time your problem will be solved.
Answered By 15 points N/A #158955
Hi there.
Yes you can shift Nexus S to the latest version of Android which is Android 2.3.3.
You will find many link for free downloads and the link is given.
  • Download the update of Android 2.3.3.
  • After downloading Copy the update.zip file onto your Micro SD card.
  • With your Nexus S hit Volume Up + Power off.
  • Then you’ll be booted into a white screen. Then Select “Bootloader.”
  • Next screen, select “Recovery.”
  • After this our phone will reboot.
  • Now press the power button and volume up button at the same time. It could take a couple of tries.
  • Using the trackball this time choose “Apply sdcard:update.zip” and let things run their course.
These are all the information and steps. (Also mention on that link)
I hope it will solve your problem.
Thanks
