Doubts in Adobe Premiere CS5
I am trying to learn Adobe Premiere CS5, but I have doubts now. I think it is one. Here it is:
While a video doesn't fit in the I use rotation or manual resize, I don't know why it is not working now. I don't know why.
Anyone have any idea, I am totally confused with this.
Answered By 0 points N/A #136032
Hi Avah,
Thanks for your query. In this situation, you need to fully understand the software usage and its needs.  You just need to use it effectively in a manner that it is meant to be used. The most probable issue may also have been with the video size that you are using. You need to ensure you use an aspect ratio of lowest 2:5 or higher 16:9
Ensure also that the software is installed properly. If it hasn't and you are suspecting of a temporary or a system file, you can check by going to the following; Going to Start > Run >Type 'temp'.
Or either, you can go to Start > My Computer > Local disk C > Windows >Temp > Adobe > Adobe Premier > CS5 in the temp folder.
In the folder, delete all the files and restart the software. It should function well. Otherwise, you may try checking with the troubleshooting guide in case of any fault or error by doing the following;
Choose File > New > Sequence.
In Sequence Presets Pane of New Sequence window,select panes that match the files.
Type the name of the sequence and click ok.
Microsoft hotfix can also solve
Restart the program.
The Microsoft hotfix can also solve in case it doesn't get solved.
