Does outlook 2007 support outlook 2000 files
 I would like to purchase a new computer with Windows 7 and MS – Office 2007. Presently I am using Windows XP and Office 2000. My Outlook 2000 ‘.pst’ file size is two GB and it gives some problem in Outlook 2000. I want to know whether the Outlook 2007 supports my Outlook 2000 file. Please help me to solve the issue. Please help me to get out this problem. Thanks in advance.
Answered By 0 points N/A #94770
Hello Mary McDowell, your issue about outlook interests me. The .pst files in your Outlook 2000 will work in Outlook 2007. Outlook supports a back up formula for your files. You need to process a back up for your files. The Outlook new versions support the old ones as well. If you have started your Outlook just look for the FILE icon then chose BACKUP you have to hit the OPTIONS button to choose the files. You need to back the .pst files up so it is easier for you also. These will fix the problem if you want to get the same files for your new Outlook.
