Does Geek Squad Charge for Diagnostic of a Laptop?
Hello friends,
I have heard about the Geek Squad and its abilities to solve the Problems quickly. I want the Geek Squad to diagnose the Errors and Problems in my Laptop. Does Geek Squad Charge for Diagnostic?
Answered By 0 points N/A #161019
If you go to the Geek Squad Counter for the first time, they will provide you a quick advice. They willask you Questions regarding the issues that you are facing, and the Experience with the problem. They will scan your Laptop with a Small Test for free, and then, they will tell you about any Trojan or Virus that is present on your System.The Result of the Scan will give a Brief Idea about the Problems in your Device. When they suggest a Deeper Diagnosis, then they will check your Hardware.
The test will be free if your Computer is under the Warranty Period. Otherwise, it costs $70.
