No of visitors who read this post: 101
Category: Apple Desktop
Type: Question
Author: Hollis Riley
No votes yet
I just bought iPhones 4 and my 3G connection doesn't work! I've researched the problem and *I think* it might be a drivers problem. Does anyone know where I could find the drivers for iPhones SIM card slot?
Or am I wrong and the issue is somewhere else? I can't call Apple's customer service, because I'm from Ghana.
Thank you.
Comment viewing options
# (Solution Accepted)
Hi Hollis Riley,
I'm wondering if you have already enabled your 3G. If you haven't, just try this: Go to "Settings", then choose "General", then 'Network; and then Enable 3G. Also, you have to restart your phone and wait 5 minutes before turning it on again. However, if it still does not work, it could be because the area where you are located does not have 3G signal. The best solution is to contact your service provider.
Hi
Surely iPhone 4 has 3G connectivity. You can use it if your connection provider supports it. This is not a big deal if the service provider’s setting s not set as it should be. Just confirm it. If that is fixed than restart your phone and switch on in 3G settings.
Jackson Paul
