DLL Error when installing Nero Ag Register Com Ex
I keep getting an error message when I tried to install Nero Ag Register Com Ex for LG DVD player.
So, it is not loading correctly.
The error message is, DLL file is corrupted in the last function.
The installation will quit. Please help me to figure out this problem.
Best Answer by Carl Jack
Answered By 5 points N/A #100015
It could be a advrcnttr3.dll is missing issue that is associated with Nero Ag Register Com Ex. It is a dll file that is present in the right folder for Nero to burn CDs or DVDs. It could be deleted or mover from its default location. Or it could be that a antivirus or other security program was removed thinking that it is a security threat or it can also be due to upgrading or reinstalling Nero.
It is important to know that you should not download advrcntr3.dll to any dll sites. If you already did, remove it and continue with the steps below:
1. A simple restart can fix the missing dll issue.
2. Uninstall Nero from your computer but remember to record the serial number of your Nero installation.
3. Restart your computer and then download Nero General CleanTool utility. Unzip the file and then run it. This is to ensure that Nero will be removed from your computer completely. But this utility tool can only work up to Nero 8. Newer versions should be uninstall completely by using the standard uninstall method.
4. Restart your computer and reinstall Nero from the original disc or from your downloaded file.
5. Install the latest Nero version to replace the missing dll files.
Answered By 10 points N/A #100016
Hello Lumori,
If you had Nero Ag Register Com Ex program on your computer and then uninstalled it, it is most likely that there are its files that remained on your computer which could possibly be corrupt registry entries and therefore you will need to remove them before you continue with the uninstallation.
  • Install CCleaner on your computer.
  • After that run it, and then use the registry cleaning option to remove any registry entry issues related to Nero Ag Register Com Ex on your computer.
  • After that you can retry the installation.
Hope this helps.
Carl
Answered By 590495 points N/A #197682
I think you are referring to the error “nero ag-Register com ex” when you install a version of Nero burning software. If you are installing Nero and a corrupted DLL file error or similar was triggered, make sure the version of Nero you are installing is compatible with your computer.
If you are installing Nero 11, it supports Windows XP Service Pack 3 32-bit only, Windows Vista Service Pack 1 or higher, and Windows 7 (Home Premium, Professional, or Ultimate edition) both 32-bit and 64-bit. It requires Intel Pentium 2 GHz or faster or equivalent AMD processor, 512 MB RAM, 5 GB free hard drive space, video card with 128 MB video RAM, CD/DVD/Blu-ray drive, and Windows Media Player 9.
It also requires Microsoft .NET Framework 4 but it should be included with the software so there’s no need to install or download it separately. If you have an existing license, you can download it again from Nero 11 Archived. Note: this is an old version and Nero is no longer providing support for this product.
